Electric System
RFvitz
ok well firstly does anyone in the forum have a nice complex ice system in his/her yaris?
got a couple questions on what the standard electrical system can take on. For example, anyone know what the standerd alternator runs at? I'm basically running quite a bit of power off it already, in fact when the bass hits hard, my lights do dim a bit, just noticeable. I've also got some neons running off it but these dont take up much at all.
Now the hard part, i'm lookin into settin up a ps2 and screen. Can the standard electrical system take this? Has anyone done this? I beleive steve ratcliffe had a few screens installed... maybe u can enlghten me.
cheers for the help.
:thumbsup:
as you hear the b-line, you use up some current in the Battery, the ECU detects this and has to do somthing about it otherwize the car will not have enough power and the car will cut out(stall). So the ECU tells the engine to rev up a bit, (you can notice this on the cockpit as you switch on the AC), which then spins the alternator bit faster to charge the Battery. The reason why the lights dim is because there is a small delay with the feedback(thats normal), to fix the prob you need a 1F Power capacitor approx 60-80 quid, I think it goes across the sub or accros the amp, you will need to ask someone else about this and I think it also gives you better sond quality.
You can run many thing on the Battery, just make sure you dont overload the battery(the battery tell you how many amp/hr) and the engine has to be running
ive got a very complex system!
4 amps
tv's
PS2
two batterys (inc. split charger)
two power caps
std alternator does alright but i cant help worrying its under a bit of strain by now so im in the process of putting an upgrade in the near future early next year
thinkin of usin a 'nator of a big v6 exec car which should kick out plenty of juice
its quite odd how the connect up to be honest you can either put them before the entire system on the main power line from the Battery or put them in the individula power lines for the amps.
ive done the latter with one cap for each of my bass amps connected directly in the lines
both input and output +ve feeds got to the +ve terminal on the cap
the-ve is purely there to earth it
it doesnt connect in series over the two terminals
a drawing will describe it better than words
LEFT TERMINAL IS +VE - RIGHT IS -VE
yup version 1.6 or summut
:lol:
top prog that i had it a while ago but lost it cos my hardisc decided to self detonate
jaxx would it be possible for you to put up some more details of ur split charge system? i am plannin to add to my install very soon but i need more power cuz just runnin one channel of my legacy amp (600w) dips the interior light!
cheers
lee :thumbsup:
wot battery/s? are u runnin and wot relay for the split charge prices and where u purchased them would be helpful too....
cheers
lee
hey jaxx....so you're sayin you've got 2 batteries hooked up to the factory alternator???
what does the standard alternator run at???
possible to post some nice pics of your install then jaxx?? i'm lookin for ideas of where to put ps2, pics would be very helpful... i was thinkin under drivers seat.
