2e Engine
talal almarafi
hi all
i have ( euroup) corolla 89 2e engine 1300 cc carb type v fron aisan
and i need vacuum diagram
can any one help me
Hi I have an '86 Corolla,2E 1300/12valve motor,and the vacuum advance diaphram went.
I couldn't get just a diaphram,had to buy the unit,Cost me about £85.from a Toyota Garage.
transformed the slow running and fuel consumption,also the emissions.
fairly easy to fit ,just take care.
regards
John
Hi chuck your carb set up in the bin & get a carb manifold & airbox from 1991 corolla in a breakers & see how well your car will run, the 89 corolla & starlet had a venturi type carb that only lasted about 70000 miles & ran really rough after that & drank petrol, take my advise it will work did it on a starlet & corolla & cured the problem, only cost £25 & a new gasket.
