I assume someone must have posted this info but a quick scan through the threads hasnt turned up what im after......
Has anyone changed the Speakers in an Aygo, If so what size are the mids in the dash and the comps in the rear doors/rear panels? And how difficult is it to get the front mids out?
Also has anyone found a convienient hole in the front bulkhead to run a power lead for a sub through to the Battery?
Front and back are 4" single-cone (paper), though the grilles make them look much bigger in the back.
Fronts are really easy to remove, pry up the grille with a screwdriver, then undo two bolts, that's it!
On LHD cars there's a big grommet near the pedalbox, I'm not sure if that's still on
the lefthand side in a RHD car, but thet grommet has plenty of space to be gapped
to feed an extra cable through, provided it's not ridiculously big...
That grommet is pointed out in the AIM for fitting front foglights. And if you're looking anyway,
have a look at the AIM for the "SoundPack" which illustrates installing (thus removing) the Speakers.
AIM's can be found here:
http://techdoc.toyota-europe.com/Aim.aspx?menuitem=2
the grommet is above the pedals on the rhd car aswell. so the other side. take a look at my post for rear speaker install and there is a photo of a badly run power cable ;) ;) jan. lol.
Cheers Chaps, As and when i take delivery i will be dropping my Pioneer and JBL system in.
