Posted In Wrong Place Gt4
zeeok
have just bought a 94 GT4 slightly damaged.......it was in a slight smash ripping the front wheel completly off and the back wheel is sitting squint its an import and as far as i can see it needs front and back n/s suspension n/s wing and maybe a new front bumper
the car was pretty cheap to buy so i think i might fix it
any ideas if its worth fixing and where to get these parts
to be honest it'd probably be cheaper buying another GT4 with an engine failure and putting the motor in from the one you have.
failing that toyota celica breakers (TCB) will have any parts ordered to your door the next day, not bad from a company down in cornwall, used them many a time
suspension on the st205 is expensive! just check the prices on sum of the items u will need! if u are talkin about all suspension gear then i would just leave it! price the lower arms fig 8 bushes. mite b hard to get the car driving straight again. hiw was it damaged. how much body work needs repared?
only n/s wing needs repaired but front n/s wheel ripped off in csash and back suspension goosed too
i got the car really cheap so thought it might b worth fixing
if not i will sell on or break it
check out www.fensport.co.uk for suspension parts. could be expensive but check it out for yourself. if your breaking then let me know. i need my engine rebored and cud b better to just buy and engine. so if ur lookin rid then let me know how much u want for the engine.
