Squising Noise From The Middle Of Gardenshaft
lestate
im hearing a squising noise comming out from the middle of the rear gardenshaft (propshaft). i have already renewed the central bearing but remained same. this squezing noise is heard mostly when reversing and when on engine break. i have hilux 4wd 1990 model. anyone has an idea of what migh be?
I am not entirely sure what a gardenshaft is.... but have you greased the grease points on the propshafts?
i have already greased all the nipples and crosses with commpresse air grease to be sure . thanks for your reply
