Estima Lucida Owner - Ready To Mod!
HyperXP
Hi all
I bought my Lucida (aKa the starship enterprise) in nov for £700 from a family friend needing a bit of work.
Its a K reg, 8 seat, 2.2TD x
Ive changed the exhaust, S.A.D.s, New 17's (yummy), Performance Filter, and still solving problems like knocks and noises. all common from what ive researched on here.
Electrically i like to mod alot, like amps, subs, Headunit, Screens, Start Button, lighting, 2 way lcd pager alarm system inc:- Remote Start, Anti Hijack, Remote CL, Imobiliser, Boot Popper, Turbo Timer, Cold Night Anti Freeze Start (10mins every 2 hours startup and run) plus more functions then i can mention.
I like to make my own electronic modules for things like one touch passenger window, Door handle (int & ext) led lighting, switch pods, Internal Lighting Dimmer, Electronic Dumpvalve etc.. If i can find something to do i'll probably do it.
My latest project is a Heads Up Display using an old garmin gps which requires a custom pod or to be set into the dash and reflected off the windscreen. I will post photos when i get started on it.
No doubt you will find me asking lots of odd and obsure questions (After fully searching first of course.)
I look forward to speaking with you all.
Hype-R
