Black Diamond Discs,
Tuned_Up_T-Sport
Ey up :D, basically i'm torn between the Black Diamond Discs and Pads or some 3G's, I know someone who is selling some black diamonds but i kno very little about them, what are they like for wear / dust, stopping ability is probably quite important, do they work with the ABS? Are the black diamond ones actually black?? May look a bit gash with silver on the back, can you get the rear ones??
Cheers yall....
i had them on my old car. very good in my opinion. give off very little brake dust and yes they are actually black. you can get the back ones yeah from fensport.
I may end up changing mine from 3g to black diamond, but there again it may be the endless pads and not the discd that's causing the problem.
I probably don't do enough milage to bed the endless one's in enough, feels like the pads not gripping on the disc, think the pads are to hard wearing.
Good thing with the black diamond is you shouldn't get any rust on the outer edges of the discs as they are black and if the discs stay black after braking so should the outer edges.
Don't know what pads to go for, I want something a bit softer than the endless, the endless are great when they work and they are dust free.
just go for the bd disc and pads. obviously going to work well. worked well from cold. barely any dust. dont go down that quickly. i had them on for 2 years after hard driving and they still had plenty of meat on them
