Corolla G6 Engine Bay For Amp +?
addz_slh
Hi guys.
I have a corolla G6 19993 model.
I want to wire up my Amplifier BUT don't know where to wire the possitive feed?
Is there a grommet i can feed it through?
I have the 4EFE.
Many thanks
i fed mine through the hole behind the suspension mount on the right, then hid it under the driver's side door sill and into the cabin.
just behind your Battery on the right there is a gromit with wires already going into the car and then through behind the glove box normally it is best to take your wheel and inner arch off to do this. I did and it was still only a 30 mins job But I have been doing this to many cars for the past 5 years for me and others.
pretty straight forward!
Remember to cable tie your new wires to the others going through above your inner arch as I am sick of hearing cars rattle from this done badly :)
Good Luck
P.S. have you checked your Battery power is ok BEFORE you make it do more work? I had to buy a new calcium HCB Battery to help me as I was already powering a lot of extras like Air Con and other electrics
You may not like Halfords but they have a useful guide on their website to inform you of how much strain you are putting on a standard battery. (Don't buy a calcium one if you don't need it, theyre not worth it)
http://www.halfords.com/webapp/wcs/stores/...ategoryId_31292
