Towing Electric Wiring
GVS
I am fitting a towbar and caravan twin electrics to my 03 avensis and was wondering if anyone can give me a clue as to where the factory fitted connectors are located for the 12N and 12S sockets hookups. This is purely to limit me removing too much interior from the boot to search for em.
I am also assuming their is a connector hookup for both wiring types since Toyota sell pre assembled wiring looms with connector block to simply clip into place.
Does anyone know the pinout of these connectors in case I decide to use the non toypta parts.
Thanks for reading.
Gary
Thanks for reading.
Gary
I guess you're sorted by now, but there isn't actually a connector as such that you can wire to. If you buy the Toyota wiring kit for 12N (There isn't one for 12S as far as I know) what you actually do is remove the pins fom the back of the light cluster and replace them with the ones in the towbar loom. It's a little fiddly but makes for a really neat job, and at £70 ish it really is worth saving yourself the hassle of cutting into the wire loom yourself.
Hope that helps (If you haven't already done it!!!)
Simon
