Help Needed Re Dash Board/speedo Lights
fiz-vvti
hi
need help re dash board lights.
my lights on the speed o and rev counter are out, the needles are fine,
how would i go about changing these and what type of bulbs will i need
thanks in advance
fiz
If the speed O and rev indicator have gone, they're little bulbs about the size of a Xmas tree bulb. Well that's waht I've found behind the dials on other cars. Though they could be LED's, as the lights are always on and they'd last longer. Normally when those lights go it's the bulbs, but worth checking that they're not on a seperate fuse. If they are that might just need replacing.
cheers for that mate, i hope its the fuse, should be easier to get that sorted.
also, just in case it is the bulds, how would i go about taking the front of it off to get to the bulbs
If you send me your email address via PM, I'll email you a pdf manual and the page number, which explains it all.
