L Think L Need A New Clutch
nightrax
I think l need a new clutch, every so often when l but my right foot down the revs go up about 500-1000rpm with not much power/speed increase then the car goes like a bat out of hell.
I'm assuming that my clutch is starting to slip ??
My question is how much are new clitch kits and do l need to do the clutch fluid with the change or does it come with the kit? And is it easer and a lot cheaper to do it yourself or is in one of those jobs were you have to give it to Mr T or a garage.
Thanks in Advance :D
unless you know wot your doin mate then no clutch isn't really an easy job, yeah does sound like clutch is on way out could be worth just checkin fluid level, but if you take it garage to get clutch done they will sort fluid as well
Ok, good idea to check the fluid level.
Will do that when l get home, otherwise l might as well bite the bullet and goto Mr T
I priced a clutch before at Mr T,it was awhile ago,think he said like £800-900,it was while i was in the uk!!!
Replaced a clutch on my old Yaris, Mr T quoted £600, genuine toyota part at my local garage £300! :wacko:
I will see what prices some of my local garage's come up with then phone Mr T for a laugh to see what he will charge.
