Fuse Box Avensis 1999
Sarah D
Hi. I rolled down my drivers window earlier this morning and it is now stuck halfway open/closed. This happens now and again but it usually sorts itself out in under 20 minutes. It has been like this now since 9.30am and I think it might rain. I need to find the fusebox so i can check it/swap fuses to get the wondpw up. Can anyone help?
Thanks in advance
theres 2 fuse boxes under the bonnet, but like you i aint got a manual and have no idea which fuses are which (im trying to find the one for the water jets??)
Ah right. That's great. As long as I know where to find the fusebox I can take it from there. If I find out which one is for the waterjets i will let you know. It will just be a matter of taking the different fuses in and out to see what they affect.
Cheers for that
Cheers for that
Found the other fusebox behind the compartment inder the steering wheel. Think the fuse you are looking for could be in there. There will be a diagram on the compartment you take out.
Have discovered that I do not have a fuse problem but that it may be the wiring or the mechanics of the wondow. Meanwhile my window is still down. Know any auto mechanics in Manchester. Can;t find one
Cheers
