Warning Light On Dashboard
DubCelica77
Well is it the case that half of your brake lights are now fog lights ? If so that is why the light is on, resolution, well easiest is to remove the bulb from the dash cluster. If you don't have fogs where the original inner brake lights were you probably have a brake bulb blown.
