Wheres My Power Gone ? Toyota
GT MOTORS
MY MISSUS HAS A TOYOTA AVENSIS D4-D EST; IT USED TO PULL LIKE A TRAIN , BUT IT HAS LOST ALL POWER WHEN YOU COME TO A HILL, WHERE AS YOU USED TO TAKE THE HILL IN 5TH GEAR NOW YOU ARE IN 3RD OR EVEN 2ND .YOU CAN BUILD UP THE SPEED ON THE FLAT BUT ITS GOT NO GRUNT , YOU CANT DROP A GEAR AND FLOOR IT TO OVER TAKE ANYMORE , IF YOU DO THE CAR YOU ARE TRYING TO PASS HAS GONE BEFORE YOU HAVE ENOUGH SPEED TO PASS IT, ALSO THE CAR HAS AN INTERMITTENT FAULT ON THE STEERING OCCASSIONALLY IT GOES NOTCHY / JUDDERY ON LOW REVS WHEN MANOOVERING ALSO THE STEERING WILL LOCK /JAM WHEN YOU ARE TURNING SAY AROUND A ROUND ABOUT ONLY FOR A FEW SECONDS [WHICH SEEM LIKE ETERNITY ] THEN IT FREES ITSELF IT DOESNT DO IT VERY OFTEN ,BUT ONCE WAS ENOUGH!!!!!!!! ANY BODY SUFFERED THE SAME AND GOT THE SOLUTION OR SUGGESTIONS? THANKS FOR ANY HELP
hello mate
what is a milage on the clock? have you stored the maintenance records?
start with both fuel and air filter changing. when was yr fuel filter last changed and check with air presence in fuel system first. are you sure your T/C works properly depending on the engine load? when were fuel valves last idle tested? as you see there are many points to be cleared.
please revert with more detailed info what is going on with yr engine
