Standard Gearbox
gt4john
Does anyone have a rough idea of what the standard gearbox on an st205 jap import non wrc will take? i have not had it long and would like to know
wot u mean? power wise? or how many miles it will last?
its ok found out now apparently ratings it can take it will take 350lbs
i also want to know is there anything i can do to car to take speed limiter off without having to replace ecu?
what speed limiter are you referring to? the top end one of 170ish or is yours a jap import and its restricted to 115?
yea the imported 115. get converted to mph? is that the only way?
there is another chip you can get that does pure de-limiting however it's not cheap or redily available, just get the e-bay one and put an 'M' sticker over the 'K' ;)
thank you for the advice gtforbes =]
