Hi,the problem is the following,when the turbo charges 4 psi the map sensor cuts the original inyection,what can i do to solve the problem without changing the factory ECU to a programable one,thanks.
There are a couple of members here that may be able to help you, if not try here: tercelonline.com pretty good forum for Tercels. :thumbsup:
