V4 Or V6
jonneyj
celica never came with a v6
And?
The v6 in to GT-S has been done. There wouldnt be enough space for the V6, 2 turbos and the heat, something would have to go! V6 with TRD superchager is possible apparently...
ok.. i read the question wrong... I thought the question meant they were changing car rather than engine.
I do not doubt the modifications you were on about. :thumbsup:
Why doesnt anyone try to put a 2jzgte into a Gen 7 Celica? :huh:
Obviously you would nee to cut some of the front of the car away to fit it in but i would expect it to be possible still.
:!Removed!:
Yeah, apart from the engine being designed for longitudinal mounting not transverse, there's no transission tunnel or mounting space for a diff or driveshafts at the back!
The engineering required to rit a 3s-gte in a 7th makes the conversion a $15000 job in the USA, hence theres only 4-5 cars running it.
Better off getting a trd supercharger and building a hefty bonnet bulge :thumbsup:
Thanks guys, i have another question.........
can u get a V4 twin turbo for a 04 Gt-S????
Um, no cos its not a VW!
Twin turbo is a waste of time on a small engine like a 2.0 V4, better off with a single bigger one.
