Help With Blitz Compressor
lwany86
Greeting everyone,
I just bought my compressor kit, and installed it with a piggyback called emanage. I bought it USED. The last owner using UNICHIP as piggyback and he got 30kg torque and 135bhp on wheel while i only got 96bhp and 15kg of torque. Why do this happen? Is it because of the piggy back? The last owner was using UNICHIP Q with turbo module. Anyone can help or explain this? Im boosting 0.6bar. Before i put on the supercharger i have around 87bhp, meaning i only gain of about 9-10bhp. Im very sad about it. Can anyone help? I heard someone saying emanage could not be paired with blitz compressor?
Hello. Do you know what size engine he had, was it the same as yours or the 1.5 t-sport? Have you got any other mods on the car or the supercharger alone? - saying this, I still would of thought you'd be getting more bhp than what you have achieved.
If you have 87bhp its means you have a 1.3RS?? it sounds like he had a 1.5RS
The emanage comes with a pre map on it which would be for 1.5 so you really need to get yours re-mapped to achieve optimal levels, if it is mapped properly you should be getting between 115-125bhp depending on your other mods, which is very good for 1.3!
You sure his figure was quoted at the wheels as would assume it is at the flywheel with that kinda figure mate. If you get the value of yours at the flywheel im sure it will be a lot more similar!
