Immobiliser
dadstaxi
Hi all i have a 1996 celica st 1800, uk spec car , the problem i have is that i laid the car up for 2 years now the Battery has gone flat, so i recharged the Battery but once re connected the immobilisor will not come off so the car wont start, any one got any idears on how to disarm the immobilisor and get the car started. Many thamks
Are you sure the Battery is any good after being left discharged for a period of time? The problem could also be with the Remote Key, have you changed the Battery in that?
yes thanks for that will get the Battery drop tested tomorrow and replace fob Battery, although the red led on the fob lights up when the button is pressed
  • 5 weeks later...
ive had a smiliar problem.
my own cars Battery has gone flat, twice.
when my Battery went flat i couldnt disable the alarm, this is because the alarm actually has its own power source so that if criminals disconnect the Battery it will continue to go off.
im assuming when u charge your old battery it goes off as it obviously connects the power to the alarm again. i had the the same problem. i connected a fully charged battery with doors being closed (this will set the alarm off) ignition off, and the alarm still kept going off untill i pressed the alarm button on my keyfob.
After this i had no probems but even since i havent been able to set my alarm without it randomly going off? stil havent fixed that ;)
Hi all i have a 1996 celica st 1800, uk spec car , the problem i have is that i laid the car up for 2 years now the battery has gone flat, so i recharged the battery but once re connected the immobilisor will not come off so the car wont start, any one got any idears on how to disarm the immobilisor and get the car started. Many thamks
hope you have the problem sorted by now if not get back to me I'll see what i can do for you.
