hi i am new to the world of previas, can anyone possibly help with a few issues i am having with reversing. the car will happily select reverse, somtimes will go by itself other times will not move until you rev to about 3000rpm and hold this amount of revs to actually move and stay moving. gearbox oil was black and burnt so has now been changed but the problem still persists. cheers gray
Get the auto box checked. If the oil was black and burnt I fear means that you can expect something bad has happened internally. Simply changing the oil is not going to fix what has possibly worn/broken inside. You could try ensuring that the selector is adjusted properly by following this link.
http://www.autozone.com/az/cds/en_us/09008...irInfoPages.htm
