Cd Multi Changer
celica140sport
hi im after a cd multi changer for my 2001 celica. its got the sony cd/tape sterio fitted in the car. does anyone know which cd changer can i get to connect to it and where i can get hold of one? cheers
I bought mine online, but can't remember where. I bought a SONY 10 CD charger (CDX-656 I think), as I thought that would be better and the 1 to 10 buttons on the fitted stereo select each CD.
Here's a couple of links to give you an idea.
http://www.caraudiodirect.co.uk/cd-changer...faeb0f4b659da74
http://www.caraudiocentre.co.uk/category_m...ngers_c-529.htm
have got a CD Changer and Sony single DIn headunit that I want to sell as a unit for £50, the 10 disc CD changer should work with no problems all the connectors are the same if your interested let me know and I'll test it as I haven't used for a couple of years and has been sitting in a cupboard
Model Numbers are:
HeadUnit: Sony XR-C5120R
CD Changer: Sony CDX-616
Model Numbers are:
hi yeh im interested. would i be able to plug it straight into the unit i have and use it straight away or will i need some more cables? also where does the changer normal go in the glove box is it?
You won't need any extra cables as I have all the cables you need, when I was using it, I had it mounted in the boot of my Fiesta, I imagine it would be too big to fit under the seat or in the glove box. One of the reasons I'm not using it, is that i'm too lazy to wire it to the boot.
There are to cable for the unit - the Control cable and and a standard RCA Audio cable, both are around 5 metres long. - Did you want the both the headunit and changer or just the changer?
Regards
Neil
