Opttional Tyre Sizes ?
chris up north
I have been looking for new tyres and on some sites it states that the sizes for the cts are 195/55/16 v or 205/55/16 v ?? is that right ?
That's correct, the alloy's can take 2 sizes in case one wasn't available.
Not sure what difference the 2 tyre sizes will make to performance/handling etc.
Some members on here have fitted the other size tho!
:thumbsup:
205/50x16 is also an option.
The differences in tyre sizes...
195/55x16.....
195 = 195mm width
55 = sidewall height is 55% of the width (195x55% = 107.25mm)
16 = Diameter of wheel in inches.
You can work the others out yourselves.. but 205/50x16 is the next best option as it it closer in rolling radius than the 205/55x16.
Thanks for that ,do I have to change all four if I go for the bigger size,
might fitting, say the fronts first freak the vsc and such out a little
I read so much about lights on the dash coming on all the time after
new tyres !!
