Snow Chains
Geezar
Hi all,
Anyone know what size snow chains can be used on Avensis Tourer T3Xs (2003). The manual says 3-4mm ones, but these sort seem to cost ~£60 and are not widely available, whereas 9mm (the standard size) can be bought for £20. Seeing as I won't be using them very often £60 seems a bit steep. Will the normal 9mm ones be sufficient? From memory the wheel size is 205 55 16.
Any help much appreciated.
Cheers.
Hi all,
Cheers.
Aah ....... it must be you that lives in the little hut on top of the Cairngorms then!
Hi all,
Cheers.
hello
i hv got chains and they r adjustable fr tires dims limits.
cheers/igor
