hi my management light comes on after starting up but if you keep revs up it does not been to numeros dealers including rmb toyota in teeside they charged me £200 pounds could not find the problem said it needs new injectors and pump costing £3200 pounds because it had traces of red diesil in it i took it away and next day customs and exise turned up to my farm and tried to dip my tank because workshop manager called them so i cant take it to them no more please can anyone help as i will not take it back to them and it wont go no where. when light comes on if you turn off then back on its ok for a few minutes please help
  • 4 weeks later...
hi i got similar but mine goes now and then it can come on when driveing or from start up when it happens engine cuts out toyota have not got a clue i have replaced glo plug regelator as it was clicking when moving but its not that have you got immobilizer im going to disconnect alarm next see if its sending wrong signel sorry not much help will let you no if i find anymoor
Mine does this too and if it helps its drivin me mad aswell the code on mine came upP1026 manufacturer specific no body has a clue
  • 2 months later...
my d4d engine hilux has a strange problem of dieing on you and no one seems to know what thats all about may well be clutch, injectors or some other eletrical component who knows but i need help as i can see somthing going horribly wrong when i try to pull out at a junction.
ps. there are some miserable :censor: about - why sould toyota phone c+e up do they want to make it hard fro the working man!
