Hi Lux Kdn165r Ecu Light
carahill
hi my management light comes on after starting up but if you keep revs up it does not been to numeros dealers including rmb toyota in teeside they charged me £200 pounds could not find the problem said it needs new injectors and pump costing £3200 pounds because it had traces of red diesil in it i took it away and next day customs and exise turned up to my farm and tried to dip my tank because workshop manager called them so i cant take it to them no more please can anyone help as i will not take it back to them and it wont go no where. when light comes on if you turn off then back on its ok for a few minutes please help
its 2002 hilux d4d
:rolleyes: Hi,
This does not sound right,cant believe a main dealer behaving like this,should report it to Toyota,They should have read the fault code and explained it to you,Red diesel in the system should make no difference at all,selling you a pump and injectors sounds like a fob if you ask me,try to get another garage to read the fault code and take it from there.
its 2002 hilux d4d
