Condensation Problem
wullieboy
can anyone help????
i have a avensis 99 model, everytime i park the car up within an hour the back window and sometimes the front windscreen has condensation on it when i start the car up it goes away once i switch the heaters on but its starting to anoy me can anyone help me with this matter
your regards
wullieboy
can anyone help????
your regards
wullieboy
can anyone come up with an answer for this
Water or cold, moist air getting into the car somehow.
Check for poor door / sunroof etc seals.
Also, look for signs of leaks; if the carpets are wet then that leads to these problems.
If non of the above try closing the vents before locking up the car.
might wanna check the seals on your windows, make sure none of them are a little bit off.
is your car stored outdoors by any chance? if it is then maybe it's because if you have the heater on while your driving and then your car cools down really quick then condensation tends to accumulate, just like the reaction that causes fog, cold air meeting warm air makes fog, hot window turning quickly into cold window makes condensation, dont know why, just an idea
thanks for reply a recently tried closing all the vents and it stoped some of the windows steaming up but its the back window that is the worst i have checked for leaks and there seems to be no cracks or leaks coming from the back window as a saftly percaution i check all the windows and there all fine can anything else be causing this
your regards
wullieboy
Could be a problem with your aircon
Had a similar problem on just the lower half of the windscreen when aircon was on but was OK when it wasn't. Had the aircon serviced as part of the normal service and have not had this problem since :thumbsup:
ave just found out by checking the car over that my aircon needs to be re-gased how can it be done and does it need to be done by a toyota dealer or can i give it a bash my self. and could this be causing the condensation on the back window
does anyone know how a can re-gas my aircon?????????
At a garage!! :lol:
Doesn't have to be at Mr T's tho
:thumbsup:
You can call out mobile Air Con people to re-gas it. Even Kwik-Fit do it now!
excellent thanks for the replies do u think this should stop my windows steaming up once ave parked it up
