Airbags
DEREK K
have a corolla T3 hatchback wondering if there's a switch to turn off the passenger airbags ? Want to put rear-facing child seat in front seat . Lots of warnings saying not to , any way of safely turn off the airbags.
Sorry, don't know the answer to your question, but have moved your thread from 'Toyota Executive' to Corolla where I think there's more chance you'll get an answer.
Yes it can be done, but a child would be safer in the back seat.
When you open the front passenger door on the end panel of the dash ( which is covered with the door closed ) , there is a slot where you can insert the ignition key, this will turn off the front passenger air bag !!!
cheers Bos , much appreciated
yep there is a little key type thing on the side of the front door im not to sure if it turns off drivers aswell just have a quick check
