D4d Fuel Economy Town/road
Mindaugas
Avensis D4D 2002 Combi
Today I tested how much diesel my avensis would use for a trip. So the results is not very good.
160.7 km with 10.55 L -> 6.5L/100 km.
Conditions: Sunny+cloudy day +6 outside, Road. Speed ~90-110 km/h, 4 passengers, tires: winter Nokian WR G2.
Computer showed: av. fuel consumption 4.9 L/100km, av speed 72 km/h
So, what do you think about 6.5L/100 km consumption? It is normal? I think it is a bit big. What can be wrong?
In towm my consumption is 9.6 L/100 km (with traffic jams)
hi mate
there several reazons that are well known, asf:
- P in tires;
- accuracy of yr display
- performance of yr fuel valves
- T/C performance
- purity of an air filter
check wth the above first -- but 4 pax must also be consired as add weight + consumption
cheers/igor
Air filter + oil changed.
Thanx for replying
hi mate
- P in tires;
- T/C performance
cheers/igor
Thanx for replying
an air filter and oil changing is not enough.
yr heart is euipped wth t/c that also works as one unit.
the more diesel consumption the less of power produced during each cycle and one'd search a reazon.
check with the listed items.
cheers
I think 6.5ltre per 100km is pretty good??
Mine reads 7.9ltres per 100km and that's 35mpg, so ur getting above 35mpg, mine's a D4D T spirit, 53, so ur car is older aswell, unless my figures are wrong I don't think ur economy is too bad at all ya know, I have a blog ongoing about htis same topic, and probably the majority are reporting lower than you!!
I have 05 T3X D4D which has now done 48k miles and I've logged all the fuel used from new. During that time I've averaged 53mpg. Most of the miles have been done commuting to work, which is 35 miles cross country on good roads. I'm more than pleased with this result.
Diesels need long runs to get economy out of them, short start stop driving when the engine does not get upto temp is no good.
I have had 30-32mpg in cold winter weather plodding along locally and 58mpg when cruising fully loaded on the A1, average
for mixed driving here in the Borders is 40-44mpg. Easy does it at all times but petrols are just as good if you do short runs
all the time.
