Passenger Seat Belt Warning Light
liamlucas
Hi, can anyone tell me if there is a warning light/buzzer for the passenger seat belt, and if there is are there any known faults as mine dose not work??
Thanks for any help.
  • 4 months later...
have a look at this thread on the Avensis forum it may help you in some way
http://toyotaownersclub.com/forums/index.php?showtopic=58191
Many thanks for this will give it a go.
IF YOU UNPLUG THE CABLE UNDERNEATH YOUR SEAT, YOU WILL ALSO DISABLE THE AIRBAG COMMUNICATION WITH YOUR VEHICLE'S ELECTRONICS!
DO NOT DO IT BECAUSE IT MAY COST YOU YOUR LIFE!
i replied same way on the other forum..
