How To Change Front Indicator Bulb?
Can anyone tell me how to change the front indicator bulb please! I've got my MOT at the weekedn and at the moment it's got one orange bulb and one white bulb!
Cheers
Matt
If it's the indicators on the bumper that everyone is wanting to change to clear then have a look at the lense. There is a small gap running vertically that you can get a screwdriver in and prize the outer section of the lense out. You should see some croshead screws in there. Remove them and you should be able to replace the bulb :thumbsup:
Hints:
Put some cloth or paper over the screwdriver to prevent scratching/cracking the plastic inidactor lenses.
It may be an idea to spray some WD40 on the screws and leave for a couple of hours before attempting to remove them.
Cool cheers for that. I thought they'd have to come out some way, just didn't want to attempt pulling them out and breaking something! I'll give it a go later on.
be carefull though as you could break the clips !
