Wire Through The Grommet ! Help
Yaris Ts
Iv got the power lead from the boot and need to run it up to my Battery. I want to take it through the grommet in the fire wall so i cut off the end of one of them and try to feed it through but it goes no where, i took my glovebox out but the heater unit(i Think) is in the way,
how do i get it through !
Help please
I couldn't get my power wire through by cutting one of the little nibs off, so I move half the grommet to one side and pushed it through that way, if you push half the wire through you should more then likely find at least a little bit of wire somewhere.
I poked a wee hole in the grommet with a knife and pushed it through, i used the grommet on the drivers side of the engine bay as its easy to get at from inside the car, the wire will come in above the pedal box.
I just used a straightened out coat hanger with the power cable taped onto it, came out in the passenger footwell no problem.
