3sgte Specs
I was looking for the specs on the 3sgte and couldn't find them. i also wanted to know a good place to buy it from not wanted to get riped off. let me know site or just tell me some of the specs. also how hard is the swap? is it something that I would want to have done or do it myself?
Which engine? the Rev 1 or 2 3Sgte? The first produces 225bhp as standard the second 245.
the rev 2. i can't find anywhere to buy it from...
I think rogue systems - http://www.revision6.com sell these, as do fensport if I remember correctly. You could also try calling CLUB MR2 on 08454582108
Just thought i'd let you know what you were in for if you undergo it alone -
firstly you have to drain all the fluids, engine oil, clutch fluid, coolent, fuel and sometimes brakes - messy job.
Then you have to disconnect everything from the engine lump - all wires, hoses, pipes and fuel lines, takes a day or so.
Then you have to remove the exhaust and the flexi - you can leave the flexi on but don't drop the engine on it!
Then whilst supporting it on a crane you have to unbolt the engine, you can either drop it with the rear axle or not. Its held in at four points, two of which are a pain in the ***** to get to.
Then you care fully drop the engine to the floor, simply pick the car up and lift it over the engine.
Then its a case of sliding the new engine under the car and reversing the process.... oh and you will need to splice in the new wiring loom and ECU - probably the most difficult job of the lot, you can't afford to get it wrong either!
All in all its one huge pain in the bum, but ultimately worth it i think!
Hope this hasn't put you off.....
Matt. ;)
