Conversion Time....
im %$(ed off with my 2's N/A lump, its constantly breaking so ive had enough of that engine and i have pulled it out.
the money it would cost to repair that engine or even replace it with a newer one is not that far behind what the turbo lumps are going for.
what all do i need to convert my rev 1 NA to turbo.
i can get engine
ecu
wiring loom
all for £500, do i need the gearbox and rear axles etc? has anyone here done this themselves and could you give me a comprehensive list of what i will need to get please.
FOR THOSE OF YOU WHO ARE JUST GOING TO SAY..." BUY A TURBO MAN ITS TOO MUCH HASSLE" THATS NOT REALLY AN OPTION!! i have a car with a %$(ed engine and a ton of money spent on it already so i just want to stick a fast lump in it and keep it as a toy, fuel consumption driveability in town and other factors associated with silly bhp cars are not a factor, i have 3 other cars and all i want is my GORGEOUS little two packing real muscle.
ps I LIVE IN IRELAND SO BRINGING IT TO YOUR MATES SHED IN MANCHESTER IS ALSO OUT OF THE QUESTION
thanks guys.
Paul
Theres a thread on imoc mate if your signed up heres the link: :D
LINKY :rolleyes:
you dont NEED a 3sgte gearbox, you can use your NA one, this is how you do it:
-3sgte flywheel
-camry/mr2 5SFE uprated clutch friction plate (it MUST be uprated due to the power)
-3sgte clutch cover
-3sgte flywheel
-3sgte clutch cover
superb! great stuff, this keeps my costs down and my options open now, have you done this? and where would i get those parts,? scrappy's? could i just use an exedy turbo clutch on the N/a gearbox?
-3sgte flywheel
-3sgte clutch cover
yes i have done this
you may get a 3sgte fly from a scrapyard, or check IMOC,
you cannot use a turbo friction plate/clutch as the splines are a different pattern for the NA gearbox input shaft, you NEED to get a 5SFE/NA friction plate that can cope with the power
you are looking at about £350 for all of the above imported from USA. you will be hard pushed to find a good/uprated friction plate in the UK
cheers bro, might just drop in a turbo box it'll only cost me £100.
ill look out for a rear end chop job.
Thanks again
the n/a box wont last long especially if you start winding up the boost
