Carina E Rear Windscreen Washer Jet
Hi, i have a carina e and the rear windcreen washer jet has always come out as a trickle, about a month ago it started working properly, a lot of gung was shot out of the jet first, but now it will not work at all, can anyone tell me how to remove the washer jet to see if it is blocked, or the tube is blocked
the tube should just pull off the bottom of the jet - then if you activate the squirters you'll be able to see if it's blocked in the tube or not.
It's more than likely the jet though, it nearly always is. Get a fine but stiff piece of wire or a sewing needle/pin and have a good ream around inside the exit hole. Failing that, new jets shouldn't cost much.
Good luck
