Gearbox Grating Noise When Not On The Accelerator
Porker67
Anybody know how I can cure the above? Usually happens in 4th, 5th and 6th gears. Can it be cured by a change of oil in the gearbox or is it more serious.
what gen car?i cant say from a professional opinion but yeah id try topping up the gear box oil also have a look at your clutch it might need tightening usually just a bolt tightening but could be slipping or the thrust bearing in the clutch
Thanks for the reply. Its a gen 7
