Creaks and squeeks over bumps and whilst cornering. If I greased lightly around the rubber seals would this help and if so....what grease doesnt perish rubber? :)
Silicone grease should not harm your rubber seals...................I hope that it gets rid of your creaks and squeeks :thumbsup:
Ta, will pop down to Halfords and post back results tomorrow :)
You could try.....
Mr. Sheen or similar household polish.
Polish the rubber really well and polish the inside of the hatch
where the rubber comes into contact with it.
This sorted mine out and also sorted out the squeeking
of the door mirror adjuster surrounds where they rested on
the window rubbers.
This is free and If you are not happy, you can then buy something.
Be careful not to catch the heated rear screen connections
in your duster though.
Ian.
