Old Question - Can't Find Answer
Hoovie
Took out radio in my 4.2 and now refitted, fuel info is in default litres/km and for the life of me cannot remember how to convert back to mpg/miles and tried hitting loads of buttons - how do you change it? :(
Push in the top right knob, it will say bass but keep rotating it until you see the KMH/MPG then change it..... Hey Presto....
Mine reverted back to standard settings when I fitted the new Battery...so all back to normal now...O and showing 47mpg as well.......but we all know they read about 4mpg out.... :unsure: :unsure:
  • 4 years later...
Anyone know if this works in a 2007 verso d4d???
I tried... but the olny options i got were bal, fad, tre and bas
Tks
The 2007 version will have a newer generation radio then the one I posted the question on, so sequence likely to be different.
Sorry I can't help further myself :(
Don't know about a 2007 but on the 4.2 the radio needs to be off when you push the button. Nothing so silly is it?
  • 2 years later...
Brilliant, worked for me. (PRESS the button till it shows l/km then TURN it to the right to change to mpg)
Many thanks
