Avensis Rattle Door Or Seatbelt Housing
2phat2slim
hi, i have a 2004 avensis saloon, which has a annoying sound ( a bit like a crunching sound, when driving ) coming from either the drivers door or seatbelt housing, i have tried to take some of the inside door panel off to take a look but cannot see anything that could be causing the sound.any help would be appreciated........cheers
I have the same thing with my 2005 avensis, at the last service I asked them to check the door seals and was told they were ok. However ,in the strong winds we had recently I could definitely hear the door moving even though it was firmly closed so I'm now thinking the strike plate needs adjusting. It's due a service again in about 6 weeks so I'll mention it again.
had the same issue on a 2004 avensis,a couple of years ago had the doors adjusted so they closed tighter on the seals
