Oil Consumption
igormus
hi Folks
As was reported by me recently it looks like I 've taken over on the subject point after have treated engine twice with additive.
2000 km are gone and real consumption is 300 ml/1k -- it is unbelievable and I am surprised.
It is again confirmed that a real problem is clogging of oil drain holes on the pistons (!). Besides -- who still thinks that the problem is with block -- i have tested compression pressure in each cylinder and it is of: 12/11.5/11.5/11.7 -- the clock shows 97800 km. I have also disclosed lack of gases penetrating into crank case vent pipe (!) confirming again the cyl lines are in limits.
good luck to everybody/igor
