Spark Plugs & Fuel Filter
killie
Hi
Was wondering whether the Spark Plugs on a 95 RAV 2.0 Litre were single or double Electrodes ?
I could take one out and look just being Lazy :rolleyes:
Also would the Fuel filter be easy to get to & change ?
Ian.H
Hi
Ian.H
Botheeeeee.......... Where are you?
Not to worried about the Spark Plug issue.
More interested in where the Fuel filter is located & how easy it is to change ?
Ian.H
It's a long time since I changed a fuel filter :lol: however, it is a pig of a job if it hasnt been changed for a while. I think it is fitted either, on the bulk head, low down, or near the fuel tank, on the body. The steel fuel lines corrode and weld themselves to the thread in the filter. Bothy might have a flame thrower to fix it with :D:
This is what it looks like
Kingo :thumbsup:
Thanks for the Info.
Their is a Black Cylinder with two pipes coming out the top
Low down on the right as your facing the engine could that be the Fuel Filter housing ?
going through the Car replacing things at the moment so thought I might as well do the Fuel Filter
Thanks Again
Ian.H
do the rav4.1 have 2 fuel filters as i thought there was one in the petrol tank at the bottom of the pump and one under the air filter box. just remember to open the fuel filler cap to relieve fuel pressure
The old Ravs ran better with twin electrode, Doesnt make then quite as jerky (esp 3drs)
Fuel filter has said, if it aint been replaced for a while (due every 27k) then it may need a feed pipe aswell
May be worth a squirt of WD40 few days before
