Removing The Black Dials Surround
SCOOB_81
Hi everyone!
Just a quick question about the black square surround, which covers the screws holding the clear plastic cover over the dials. It's canny embarrassing, but is there something I'm missing for removing the screw, which hangs vertically from the top of the surround cos like hell will it come out - it just turns and turns!!! I've got a rattle from the top corner and if I keep the clear plastic cover pressed it stops, so I suspect it's just a loose screw, but I can't get in at it. Has anyone else removed it?
Cheers! :)
i was pulling it the other day and it seems its clipped in with just one screw facing upwards may need a short handle screw driver but im sure it clips out after that screw is removed.
I had mine out (so to speak) last year, i'm sure its just the one screw...
Cheers for that fellas! :D
I thought that was all there was with screws, but it just keeps turning. Hmmmm. I'll have another crack at it later!
