Front Suspention Noice Over Speed Bumps
Is this a problem with the car? Whenever I go over speed bumps slowly now the front suspension makes a squeaky then squeaky-grating sound?
The front of the car is allot lower to the ground at jack points than the back of the car! Is this normal?
I got the car with 10,000 miles on the clock but strangely odd tiers across the leftside and the sound is coming from the left side. I have a feeling that the car has had a knock with the previous owner and something is just not right with the front suspention.
That car is under warranty, so go talk to your Toyota garage.
That kind of sound isn't normal. Try other Auris and compare it, you will notice the difference.
I just don't want to look paranoid.
my previous car started to squeak,.... a bit like old bed springs, when driving over speed bumps. i had it checked out, and was told, it was down to worn ball joints and bushes ! :thumbsup:
