Flashing Some Yellow Sign In Sign Board
monq
It's not the exhaust emissions light, it's the engine warning light.
Could be a number of a few hundred problems. Most common are Air flow sensors and the sensors in the exhaust.
What you need to do is take it to a garage who can stick the ecu to a computer to read what the code is, once this is done you should know what the problem is from the code coming up.
Your best bet is to take it to a toyota dealership, although they charge a bit more for reading the code they should have a list of what the codes are to find out the problem, whereas an independent garage may be able to get you a code they may not know what problem the codes refer to if they don't have the code lists.
And the only code list I know of has a few missing.
