Gearbox Problem (d4d)
rizzla664
hi new to this forum, iv had my 2002 avensis d4d (old shape) for 5 months now without any problems past few days iv been experiencing problems changing gears, changing from 2nd to 3rd and 4th was very hard i mean hard. tho the gears were fine if i was changing while car was ticking over. so i had gearbox oil changed and used some molyslip treatment which did not help.
tonight i was on me way home from work was in 2nd gear came to slight hill as soon as i put put down in just made some nasty crunching grinding noise and i lost all drive eventually i rolled to a stop it goes into all gears fine but no drive soon as i bring clutch to biting point is just grinds and crunches but car does not go no where.
about 1000miles ago i had a Blueprint clutch kit fitted could it be faulty clutch??
I could look at the pressure plate...
if not could be the sycrnos
just had it recovered to a garage they think its flywheel. have to wait till they open it up get a better idea.
If it was the flywheel
then you would have heard it knocking on start up..
or whilst its running.
+ flywheel wont cause crunching noises.
Id be very suprised if it was.
