Dashboard Lights
Guest Snowy3
Guest Snowy3
What is it with my RAV and lights at the moment?????
Anyway i noticed yesterday that although my headlights work fine the dash light doesnt come on when i have them switched on. I get the blue light when i have my main beams on but not the other light when you just have the normal beams on. It used to work.
Any ideas??
Any ideas??
I wish I'd spent a bit more time checking the bulbs behind the dash when I had the thing apart - I have several bulbs out on my dash around the heater controls and the clock hardly ever works. I changed all the bulbs on my Renault Trafic and that was easy.
I assume that the RAV has the same sort of wee bulbs as the Renault. Its just geting to them - the dash needs loosened off - not difficult - just time.
I'm working with my son using LED lights as they last a lot longer and we are experimenting with small panels and stuff bought from RS components. I also fancy the gadget from germany about monitoring horsepower/etc
Are you sure there is a dipped beam light?
Can you take a photo snowy?
