Set Destination Voice Command?
Chris Ray
I understand that the UK sat nav voice commands do not let you set a destination?
However, there is a set destination command, but when trying this it says it is only avaliable in the "scrolling map" and i cannot find which map that is!
Any advice appreciated.
If you have memory points set like "home" and the map screen is up, you can say "home" and the the system will allow you to say "set destination" or "add to destination".
have fun, the T.rt very often misinterprets and trys to add more icons!!!!
:o
Thanks, i think I have worked out the scrolling screen bit. When you move the map view by touching the screen, you can then say set destination and it adds that point!
Know what you mean about misinterperating the commands, I get some strange icons added!
Like the I'm Hungry command though.
