Lightweight Pulley Kit
Norfolk n Chance
Found a kit for the Celica T Sport.
The Alt pulley is a different size so it would need a different sized belt in order for it to work.
Question is, if i changed the size of the belt in order to get this to work would it affect the engine in any way??
:help:
Go for c-ne pulleys kit!
The engine response is lighter.Combo them with 13.0 TRD pistons will be a nice job!
They do, £799 from Fensport for a TRD High Compression Piston Kit.
:help:
If you change the size of the pulley you change the speed of the, in this case, alternator
