Looking For Rhd Revcounter Base
Hi all,
This might sound stupid, but I'm looking for a BASE for a RHD revcounter.
I allready tried 1stchoice.co.uk, but they quoted me for a complete counter,
which is a waste of parts and money, as I really only need the base or even
just the metal plate beneath the plastic bit.
I borrowed some pics from this forum and outlined what I need:
And for those wondering: It's for a little project of mine and I can't use a base
for a LHD car, as thet position is allready filled by the revcounter :D
So if anyone on here has an idea where I could get what I'm looking for...
I'm allmost wishing someone will roll their car, ruining the revcounter,
just so I can have the base, but thats just a bit too harsh...
No One???
You tried the Pug 107 OC forums aswell?
Yeah, as well as Toyota UK, Peugeot UK and Citroën UK...
I tried 1stchoice.co.uk again, but got a second quote from the same breaker
for a complete revcounter, only this time at 160% of the initial quote...
At the moment I'm researching having the metal bracket (that's what I REALLY need/want)
copied as a mirror of my existing bracket. Doesn't have to look good, just has to work...
go on....is it for a turbo boost guage....? tell us it is...... :D
No, it's not for a gauge, but I WILL be mounting "something" there to get the real Mickey Mouse effect :D
  • 8 months later...
Well, it's been quite a while, but thanks to REFZ I finally did get a revcounter through eBay.
Actually it was the ENTIRE speedo-cluster from a crashed 107, so the cover is a bit marred,
but since I'll probably end up using only the base it 'll be fine.
Today I mounted the RHD counter next to my original LHD-one and hooked up a second plug to the stock wiring;
the breaker snipped all wires instead of unplugging them, so I had about 3" of loom from the counter base
which I could use to make an exact copy of the OE-plug. The device I'm going to mount needs a power supply
anyway, so I thought I might as wel use the existing plugs to make it easier to install everything...
So to make a long story short: I now have TWO revcounters on mine, working simultaneously :D
Please wait a few seconds for Video to load!
Well, it's been quite a while, but thanks to REFZ I finally did get a revcounter through ebay.
I must ask WHY?.....................From your Video they do not appear to be in synch :unsure:
Going to get a third one? one for each cylinder then.
No sorry forget the comment must be the New Year hangover.
I must ask WHY?
Simple; I couldn't resist doing this for the time being...
The second revcounter (the RHD-one) will be modified into a TomTom-cradle. That way
I will have my TomTom within reach, which it isn't when mounted on the windshield.
It will also be in the same focus-depth as the speedo and revcounter,
so glancing at the TomTom will be way easier, quicker and safer.
The TomTom need to get power, so I thought I'd use the existing connector on the base
of the revcounter. Since I was soldering anyway I made all 5 connections, so it doesn't
matter which plug is plugged intoe which base. And when I had all connections in place
I just HAD to try if it would work with two counters installed.
The next couple of weeks Ill be modifying the counter and/or base to teke the TomTom.
But I have a lot of the projects as well which might be more "pressing" to have this winter.
These include heated wingmirrors, a variable intermittent wiper up front and an actual
intermittent wiper in the rear with washer-delay, started through the OEM stalk-switch....
They ARE, but they don't start out at the same level.
So they point at the same rpm, but they ave different scales; left starts at
8 o' clock, right at 9 o' clock and they both end at different positions too...
Looks like Mickey mouse!! :P
Strange addition but if that is what you like then good for you :thumbsup:
As I said before, this is temporary...
Here's what I have in mind (minus my hand of course):
  • 4 months later...
Meanwhile my TomTom has been fitted according to my plans, so this topic can be lockd and/or removed...
As requested
This topic is now closed to further replies.
