Runx
badger1922
Looking to purchase a corolla RunX 4WD auto, uk registered or consider a import can anybody advise/help
i havent see any Runx 4wd so far, escpt that RUNX rally one
it would be costly to repair,
also car made it japan or asain, their body work is not as good as European (number of layer of paint and metal they used are a bit thinner),
if u used them in UK, they may get rusted more quickly, especially during winter, salt on the road, will cause the bodywork erode more quickly.
however, 4Wd, must be fast,
I know of only one in the UK. FensportCorolla4wd.htm
This was imported before the import rules changed so don't expect to see any more.
From the Fensport site - it says that the 4WD auto has a 1500cc engine - so not particularly quick.
You can get a 1.8 4WD Run X / Allex, 125ps 1ZZ-FE so not quick as the T sport, regarding paintwork didnt know japan ones is thinner, i was told USDM cars in general has thinner paint work due to their stricter regualtions so different / less harmful chemicals in the paint is used!!
when i been to hong kong last summer, i have go to see second cars, saw a runx , and rush the door , the metal is softer than Europe corolla, i reckon it is less idle especially higher speed limit in UK than japan....
