7afe Engine - Where From?
Trouble
Have you considered buying an accident damaged car? I bought back our Corolla for about £150 after it was written off and it was mint (apart from the big dent in the boot that wrote it off of course - but the engine was perfect). Typically insurers sell them back at about 10% of their undamaged value, so that's a few hundred quid at most for almost anything with a 7A-FE in it. You can make a few quid on the bits you don't need too.
Any suggestions?
Mine has a very noisy top end knock.
Paul
if you look on raw2k's website (online auction that sells cat c's and d's) you should find a celica st or corolla gxi etc.
they useually advertise on exchangeandmart.co.uk also, you might find it is easier to find stuff on there as the raw2k website is a bit kack
altenatively i have a corolla gxi for breaking which has a 7a-fe in it, only problem is that there is 100k on it, but at least you know it works
Any suggestions?
Paul
Where is the car mate?
Any suggestions?
Paul
The car is in loughborough, leicestershire, after driving it today, the bottom end sounds a little worn but the head is fine. Your more than welcome to come and have a look
If your interested pm me your number and I will give you a ring
Gonna be keeping the car so need a good engine, thanks anyway
Paul
Any suggestions?
Paul
